Activity › Forums › Apple Final Cut Pro › export image and mov with alpha
Posted by Anita Sancha on November 14, 2014 at 11:50 amHi… I have experimented with compressor and can’t seem to export an animation with alpha to AE
I usually use uncompressed animation with colors + so that I get alpha or png sequence/ png (this is not an option in compressor)
It seems the default FCPX background black will not enable a transparent layer.
I have clip exporter but can’t still seem to create alpha areas. using xml too. any ideas of work around for AE and photoshop?
Thanks for all your help
Anita Sancha.Anita Sancha replied 11 years, 10 months ago 3 Members · 8 Replies -
Jeremy Garchow
November 14, 2014 at 1:07 pmSet your project settings in FCPX to Prores 444, then export “same as source” in the share window.
If it’s still not working, delete your render files for that Project and try again.
Anita Sancha
November 14, 2014 at 1:56 pmThanks a bunch….. took a while, however some of the clips DO work, but “Slide” theme effects clip didn’t.. (it has an alpha opening ) which I wanted to transfer in its own write with alpha to AE……hense some confusion while experimenting….but I have got “IT” for the future
Anita Sancha. -
Charlie Austin
November 14, 2014 at 4:38 pm[anita sancha] “however some of the clips DO work, but “Slide” theme effects clip didn’t.. “
Do you have Compressor? Assuming you’re using the latest versions of everything… Go to your fop x share preferences and bring in this setting from compressor:
Something changed recently with alpha exports, but that’ll do the trick. 🙂
~ My FCPX Babbling blog ~
~”It is a poor craftsman who blames his tools.”~
~”The function you just attempted is not yet implemented”~ -
Anita Sancha
November 14, 2014 at 9:17 pmThanks…. I have done that now, but oddly enough it still does not work with this theme effect.(Themes/titles/slide the one with title and subtitle) Perhaps its in some sort of script !!!
If I delete the theme effect the timeline WILL output with alpha… if I put it back the rest of the clips don’t either…. very strange. but thanks the new compressor destination with pro res4444 with alpha is now there as a detonation when to works.
X hugs guys.Thanks for all your help
Anita Sancha. -
Charlie Austin
November 14, 2014 at 9:21 pm[anita sancha] “Thanks…. I have done that now, but oddly enough it still does not work with this theme effect.”
Just an idea… maybe copy/duplicate a little section of your cut to experiment with, and try changing the composite mode on the title to some different modes and exporting it. Maybe another setting will work?
Jeremy Garchow
November 14, 2014 at 9:36 pm[anita sancha] “pro res4444 with alpha is now there as a detonation “
Just as long as it’s not like this:
https://www.youtube.com/watch?v=Krf01aujdJ8
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Anita Sancha
November 14, 2014 at 9:57 pmHa ha ha LOL… my typing is bad and the prescriptive script makes it worse. LOL
Anita Sancha. -
Anita Sancha
November 14, 2014 at 10:04 pmgot around it by taking the mov file into AE … output as png sequence ….. opening in photoshop each still ….selecting with magic wand … then cut the shape and batch save … then reload footage into AE worked fine and took only about 20 mins. …… zzzzzzzzzz but a bit tedious !!!
Anita Sancha.
