Activity Forums Adobe Illustrator Export Illustrator Layers to Photoshop that will remain as editable vectors (Smart Objects)?
  • Export Illustrator Layers to Photoshop that will remain as editable vectors (Smart Objects)?
    Posted by Nikola Tomic on November 6, 2014 at 11:15 pm
    Hi guys
    I was trying everything, but none of tutorials helps.
    I am trying to export Adobe Illustrator file [a bunch of grouped characters with groups and layers] to PSD and this file to animate in AfterEffects later. What I want is – to all PSD files exported from Illustrator to remain editable in Illustrator [as vectors] or as Smart Objects.
    Exporting AI to PSD converts all files to 72/150/300/other DPI which are bitmaps and I don`t want that. The only one way layers stays as vectors is to manually COPY and PASTE layer by layer from AI to PS… which is extremely long work… 🙁 as each layer has to be moved and centered where it should be. I couldn`t find “Paste in Place” as it works in AI…
    Maybe there is a script to do so or something?
    Thank you very much!
    N.
    Nikola Tomic replied 11 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
