Activity Forums Adobe Illustrator Export Illustrator Layers & Elements to a Spreadsheet
  • Export Illustrator Layers & Elements to a Spreadsheet
    Posted by Joe Truesdell on November 25, 2009 at 5:20 am
    Here’s a tricky one.
    I’m putting together a mock-up for an AJAX website using layers and shapes to build buttons and menu items.
    I’d love to be able to export all of the layers into a text file containing: layer/element name and the x,y,w,h values for each. That way I could hand over a spreadsheet with mock-up images to a web developer to use for pixel accurate placement.
    Anyone out there have any ideas (hacky or otherwise)?
    Thanks a lot.
    Joe Truesdell
    Technical Director
    http://www.globalmechanic.com
    Kimberley Hansen replied 14 years, 5 months ago 3 Members · 4 Replies
  • Vincent Rosati
    November 25, 2009 at 7:35 am
    I don’t have the answer for this, but I might consider looking into Illustrator Scripts.
    Here’s a guy who has some nice ones…
    https://vectips.com/tricks/10-free-and-extremely-useful-illustrator-scripts/
    Honestly, I’m not sure if scripting will allow you to do something like write a text file, or if there even might be a way to extract the layers data from the AI file as a TEXT file, but it’s an area to explore.
    If you do find a solution for this, please let us know.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Joe Truesdell
    November 25, 2009 at 10:02 pm
    Thanks Vince,
    Found some very useful scripts from your link.
    Nothing that addresses this but I’ll keep looking around and post any solutions that I find.
    Joe Truesdell
    Technical Director
  • Joe Truesdell
    December 3, 2009 at 1:59 am
    Hey Everybody,
    I just thought I’d share what I ended up doing to solve this workflow idea I had. It may end up being helpful for graphic designers that would like to produce XML code from Illustrator layer information to pass off to web coders.
  • Design ALL web elements in Illustrator
  • Download a copy of Adobe Catalyst Currently in free beta period.
  • Open Catalyst and create a new project by importing your Illustrator file.
  • After import, goto: Window> Switch to Code workspace
  • Copy all of the code to a new text file.
  • Send the Illustrator file and Code containing Text file to web developer.
  • With these 2 files the web developer can re-build everything in DHTML with x,y w,h values that match the elements in your Illustrator mock-up.
    Excellent.
    I hope that helps.
    Joe Truesdell
    Technical Director
    globalmechanic.com
  • Kimberley Hansen
    April 9, 2012 at 7:53 pm
    April 2012 Update:
    The above steps will only get you the top-left corner coordinates of any given shape…the same coordinates one can get by saving the file out as an SVG. After having done a thorough internet search, I conclude that there is no way (at present) to export the CENTER coordinates of layers from an illustrator file. I may write something myself…or I may just go in and transcribe the coordinates by hand. If I write a script, I’ll post back here.
    Happy hunting, internet future-persons.
  • We use anonymous cookies to give you the best experience we can.
