Activity Forums Apple Final Cut Pro Legacy export headache with FCP6 and Compressor 3
  • export headache with FCP6 and Compressor 3
    Posted by Gary Huggins on April 25, 2021 at 9:43 pm
    I’ve been working on a feature for a very long time – so long, in fact, that I’m still using FCP 6.0.6 with Compressor 3 on OS 10.6.8.
    I have exported previous cuts in the past without issue. Now that I have a final cut, however, I’ve hit a snag.
    When I try to export, whether through FCP or Compressor, the project gets hung up.
    I suspect that this is due to the size of the project file, a ridiculously bloated 328mb.
    The previous cuts I successfully exported were also way too big, around 250mb, but at some point this final – and shorter – version grew by a mysterious 100mb.
    I’ve tried to slim the file but nothing works. I’ve purged it of everything but the sequence I’m exporting, I’ve deleted everything but the current project’s files in Render Manager and I’ve removed all markers. It’s still 328mb.
    One clue: the opening FCP prompt declares 1200 render files missing – but the Reconnect screen shows no render files at all, and nothing to reconnect or dismiss.
    Could my project be haunted by the ghosts of 1200 render files?
    If so, how do I exorcize them?
    Thanks in advance for your advice.
    Gary Huggins replied 5 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • Andreas Karoliussen
    April 25, 2021 at 10:18 pm
    Sounds like a corrupt render file is your issue… or a reference to such.
    Try making a new project: called “exorcist” or something completely different from your other project.
    Create a new timeline / sequence
    Copy paste all content from old timeline to new timeline. (maybe you have to take section by section because of memory usage)
    A few years since l did this, so I hope l remember the “steps”.
    Hope it helps!
    Good luck!
  • Stephen Hopes
    April 25, 2021 at 10:19 pm
    Hi Gary
    If deleting all preference files didn’t work I would export an xml of the final sequence and import it into a brand new project…
    good luck with it
    Steve
  • Gary Huggins
    April 25, 2021 at 10:59 pm
    Thanks Andreas, I’ll give it a try.
  • Gary Huggins
    April 25, 2021 at 11:01 pm
    Thanks Steve, I’ll try that next. Will I need to delete all the render files and completely re-render the entire project?
    April 26, 2021 at 8:17 am
    Yes, with either solution it would be necessary to re render it all.
    If you experience the same issue in compressor again I would take section by section through compressor and see where the buggy transition or file is.
  • Gary Huggins
    April 26, 2021 at 2:17 pm
    Thanks Andreas, if slimming the project file doesn’t help I’m going to install Pro Maintenance Tools and use its corrupt file finder.
  • Gary Huggins
    May 22, 2021 at 3:37 am
    Update: I was able to both shed the phantom render files and shrink the project to a reasonable 57mb by combining both suggestions above. Thanks again for those.
    But the project still won’t export. When exporting to Compressor, the project gets tantalizingly close to completion before crashing with a EXC_BAD_ACCESS (SIGBUS) error.
    I’ve read this can be due to either bad RAM, or a bug in the software.
    Unfortunately I can’t open the Apple Hardware Test to check my RAM (nothing happens when I press D on startup), but I did save the crash report, attached.
    To anyone who can interpret it, who does it implicate in the crash – the RAM or a bug?
