Activity Forums Apple Final Cut Pro Legacy Export HDV to WMV wrong Aspect Ratio
  • Export HDV to WMV wrong Aspect Ratio
    Posted by Maria-luisa Meredith on July 3, 2012 at 7:37 am
    Hi
    I’m working on an HDV project, the client has requested a .wmv file.
    I have Flip4Mac installed but whenever I attempt to export a .wmv from FCP the outputted file is 4:3.
    I’ve exported .wmv from FCP before (1024/576 project) so what can be happening here with the HDV format that’s causing the wrong aspect ratio to be exported?
    Any help greatly appreciated.
    M
    Sequence Settings:
    Frame Size: 1440×1080 / HD (1440×1080)(16:9)
    Pixel Aspect Ratio: HD (1440×1080)
    Anamorphic: Unchecked
    Field Dominance: Upper (Odd)
    Compressor: HDV 1080i50
    Macbook Pro / OSX 10.6.4 / 2.4GHz Intel Core i5 / 4GB 1067 MHz DDR3
    FCP Studio 7.0.2
    Maria-luisa Meredith replied 14 years, 2 months ago 2 Members · 2 Replies
  • Brad Elliott
    July 3, 2012 at 3:20 pm
    1024×576 is SD PAL anamorphic not HD.
    What version of flip4mac do you have?
    The Studio Pro HD version($179)is the only version that I know of that will do HD.
    FCP recognizes the rectangular pixels of HDV and should be displaying your 1440(anamorphic) footage correctly on your system and/or HD monitor.
    My guess is Flip4mac is seeing 1440×1080 as 4×3(which from a pixels only standpoint it is). This is most likely do to not having the HD version of Flip4mac which can process the rectangular pixels of your 1440 footage into a square pixel HD wmv.
  • Maria-luisa Meredith
    July 3, 2012 at 3:45 pm
    Of course, that makes sense! I just assumed if F4M could see the 16:9 format it could export it too.
    Thanks for the heads up, I’m downloading the trail version of F4M HD now.
    Thanks again.
    Maria
    FCP Studio 7.0.2
