Activity › Forums › Apple Final Cut Pro Legacy › Export HDV timeline
  • Export HDV timeline
    Posted by _lakey_ on May 27, 2007 at 12:54 pm
    There is a problem I think Apple needs to fix…
    I am editing a HDV sequence (1080i 50). The sequence settings have it so it be rendered to the ProRes 422 codec. So I let it render overnight.
    Now… I need to take this sequence and export out a Quicktime file so I can save on DVD or portable HD to give to someone else. When I go to export the timeline, it seems FCP is re-rendering it again for export (it’s giving me the same estimated time to render) when it should be fairly fast… usually.
    What export settings do I need to put out for it to export my timeline as quickly as it has in the past using the DV codec?
    Chris Borjis replied 19 years, 4 months ago 3 Members · 2 Replies
  • Steve Connor
    May 27, 2007 at 6:47 pm
    Perhaps it’s not an FCP problem but it’s a settings problem?
    What export settings are you using.
    Steve Connor
    Adrenalin Television
    Have you tried “Search Posts”? Enlightenment may be there.
  • Chris Borjis
    May 27, 2007 at 7:35 pm
    what if you next the HDV sequence into an SD pro-res sequence and export it that way?
    You should not need to render the timeline unless you intended to play it out from there directly to a tape deck to ensure full res realtime layback without dropping frames.
    If I read you correctly that is. 🙂
