Activity Forums Adobe After Effects Export HDRI map from AfterEffects
  • Export HDRI map from AfterEffects
    Posted by Petar Pavlov on July 9, 2009 at 9:42 pm
    Hello guys,
    Does anyone know a way to export a HDRI Map from an Aftereffects 3D scene that can be later used as an environment map in 3ds max?
    Les Nemeth replied 17 years, 1 month ago 2 Members · 1 Reply
  • Les Nemeth
    July 11, 2009 at 12:06 am
    Make sure your AE project is in 32bit mode.
    Method A:
    1. Composition > Save Frame As… > Photoshop Layers
    2. Open the file in PS then Save As EXR or HDR format.
    Method B:
    1. Render the frame(s) as usual from directly from AE, and specify either OpenEXR or Radiance sequence from the output module setting
