Export HD to SD DVD with high quality – answers
I’ve seen a lot of posts about this all over the internet. Here’s what I’ve done which seems to work great for anyone stuck
1) Create cut from export, or original edit, using the same settings.
2) Create new sequence as DV PAL Widescreen 48Hz.
3) Drop the dvd SEQUENCE onto the new DV PAL sequence, and scale up to fill frame.
4) Export as MPEG-2-DVD and set field order as progressive and up the bit rate.
5) Open Toast or other, drop the video and audio in, they’ll be 2 separate files.
6) In preferences set the field order as progressive, check bit rate and click burn.
