Activity Forums Apple Final Cut Pro Export HD from FCP X to get the best results on DVD
  • Export HD from FCP X to get the best results on DVD
    Posted by Rowan Banks on September 5, 2011 at 8:18 am
    Hi
    I’m sure this has been covered many times, but I was unable to locate a clear answer. There is loads of stuff on the web, but nothing that seems like the final answer.
    Please excuse my basic understanding also.
    Right. I have a Wedding film that is just a smidgen over 2hours and was filmed in full HD (1080i HD, 25i) and is showing as Apple Pro Res 422 on the timeline.
    I have tried exporting in various different ways and am using a Dual Layer DVD, but both Compressor & “Share to DVD…” both use MPEG-2 compression which creates a fair amount of nasty artefacts in the finished film. Not to mention I have little to no control over the DVD menu and Chapter markers.
    I have been able to add chapter markers by creating a .txt file and importing that via compressor however.
    I guess my question is: What is the BEST setting to export this footage in (presumably through compressor) to ensure the sharpest result in terms of the finished film?
    I should mention I do have DVDStudio Pro 4 on another Mac, so perhaps the answer is to export from FCPX as “Export Movie” and then move the subsequent massive .mov to that but I may also need guidance in what settings I should be using within DVDSP as well…. :s
    It just seems there is so much info about encoding HD/SD, DVDs, etc out there I feel a bit overwhelmed.
    I have been playing with the trial & error approach for a week now, but due to the size of the file this is costly both in terms of wasted discs and wasted time.
    Any help would be greatly received as the couple are waiting for their finished film…
    Rowan Banks replied 14 years, 6 months ago 3 Members · 7 Replies
  • 7 Replies
  • Craig Seeman
    September 6, 2011 at 8:34 am
    [Rowan Banks] “full HD (1080i HD, 25i) and is showing as Apple Pro Res 422 on the timeline.”
    I’m not sure what you mean by this. The timeline supports ProRes 422 regardless of source.
    [Rowan Banks] “DVD…” both use MPEG-2 compression which creates a fair amount of nasty artefacts in the finished film.”
    DVD video is MPEG2. It doesn’t inherently cause artifacts. That may depend on source and settings and how good Compressor is at encoding MPEG2 (there are better encoders).
    [Rowan Banks] ” Not to mention I have little to no control over the DVD menu and Chapter markers.”
    That’s true for sure. DVDStudio Pro would be the way to go for authoring DVDs.
    You’d still have more control over encoding the MPEG2 Elementary Stream in Compressor. DVDSP can encode but it’s simply using the same engine with fewer user controls.
    [Rowan Banks] “It just seems there is so much info about encoding HD/SD, DVDs, etc out there I feel a bit overwhelmed.”
    The single biggest issue is doing a good downconvert. There are as many formulas as their are compressionists so it seems. There’s a couple of good articles about this by Alister Chapman.
    https://www.xdcam-user.com/2011/03/getting-good-sd-from-an-hd-camera/
    https://www.xdcam-user.com/2009/11/getting-sd-from-hd-and-the-problems-of-oversampling/
  • Rowan Banks
    September 6, 2011 at 8:54 am
    OK, cheers for getting back to me Craig.
    I have managed to achieve a high quality result overnight, here’s what I did:
    FCPX – Share>Send to Compressor – Setting Apple>ProRes 422. Imported the Chapter List .txt file and submitted. It created a 114GB .mov file which I thought would be a problem, but I simply imported that into iDVD and the chapters came through with it.
    Changed the iDVD settings to Dual Layer and encoding Best and off it went.
    The results were the best I’ve seen in the week or so I’ve been fiddling. And although the iDVD menus aren’t as nice as DVDSP, at least I have a suitable product.
    I think previously I was using compressor/FCPX to get a MPEG-2 file which iDVD/Toast/DVDSP would then compress to MPEG-2 all over again.
    Pro Res is obviously the best way to get the film into a suitable file for these programs to recognise without losing any quality.
    Seems quite obvious now, but I really struggled to find this process anywhere.
    Anyway thanks for your help and I hope others find this useful.
    iMac 2.7GHz Intel Core i5, 27″, 16GB DDR3, 10.7.1, FCPX
  • Craig Seeman
    September 6, 2011 at 1:28 pm
    [Rowan Banks] “I think previously I was using compressor/FCPX to get a MPEG-2 file which iDVD/Toast/DVDSP would then compress to MPEG-2 all over again.”
    Absolutely a workflow to avoid in iDVD. You want a heavily compressed file to be compressed again. It is possible to hand a well compressed file to Toast or DVDSP without it begin re-compressed.
  • Ai Zad
    February 14, 2012 at 10:52 pm
    Thanks Rowan for sharing his workflow… i was facing the same thing before, not knowing what settings to export out from fcpx..
    What i did before was just exporting current settngs from FCPX then putting that .mov file into toast and i get poor noticeable final product in DVD..
    i was searching everywhere in the net for a proper workflow and i finally read your post..yes, we cannot get the same quality since its in dvd format but its much much better and suitable end product.
    The only problem was the exported ProRes 422 took up a lot of space in my hard drive.. lol
    If there are others out there who are willing to share their workflows in creating a DVD final end product with less trouble.. pls share.. 🙂
    Anyway Rowan thanks again..im settling with this workflow tho its filling my harddrives and ittakes much longer time to encode in idvd( mine is 3hrs plus for full single layer burn) mind sharing how long it took yours??
    thanks again..
  • Rowan Banks
    February 15, 2012 at 8:36 am
    Hey Ai Zad
    No problem, glad to share.
    It does indeed take up a lot of hard-drive space, and takes a long time for iDVD to produce the final disc, but at the end of the day that’s just a sacrifice I’m willing to take t ensure my finished film is as good as I can get it.
    I’m investing in more external hard-drives now 😉
    iMac 2.7GHz Intel Core i5, 27″, 16GB DDR3, 10.7.2, FCPX
  • Ai Zad
    February 16, 2012 at 11:22 am
    hey rowan,
    Good day to you ,
    just checking… did you create your markers in compressor or fcpx? if you did it in fcpx .. you mention importing markers text list/files.
    if you dont mind can you share with me how you do that??
    thanks again.
  • Rowan Banks
    February 16, 2012 at 12:33 pm
    Hi again
    Nah, infuriatingly FCPX doesn’t support chapter markers….at least, not yet, anyone know if they have been added in 10.0.3?
    Assuming Apple still haven’t sorted this, then the process I outlined in compressor is probably the best….
    With them adding in MultiCam and various other functions into FCPX recently, I’m confident that they will get round to this and perhaps looking at the DVD authoring side of things over the next few months (at least I HOPE so!!)
    Glad to help.
