Activity Forums Adobe After Effects Export HD footage from Premiere cs3 to After Effects cs3
  • Export HD footage from Premiere cs3 to After Effects cs3
    Posted by Warrick Heever on January 7, 2009 at 12:00 pm
    I want to know how does one export HD footage from premiere to After effects. I recently bought a sony Z1 (1080i) and and have used it for SD till now. I am trying to export my captured footage to AE CS3 so that I can do some effects work to the footage then send it back to Premiere pro.
    Do I need a 3rd party plugin to do this? Cineform,Raylight,Lagarith,Mjpeg2000 Prores etc.
    Do I export it as High quality mpg2?
    Is there anywhere I can find a tutorial on the correct workflow for this?
    or last resort
    Do I rob a bank and buy a Mac?
    Thanx
    Warrick Heever replied 17 years, 8 months ago 3 Members · 3 Replies
  • Jack Watts
    January 7, 2009 at 12:59 pm
    Instead of writing what i know about dynamic link here. Hopefully this article will be of some use to you.
    Article
    “Simplicity over limitation”
  • Scott Roberts
    January 8, 2009 at 4:22 am
    I would render out using Quicktime Animation, or Quicktime Photo JPG, then open that in AE. Granted, this would be a “flat’ version. Depending on what you want to do in AE (color grade, etc), this could be all you need. After you’re done in AE, render out in the same manner – Animation, Photo JPG, etc. This is a simple approach without really knowing what you’re trying to do. Hope this helps! Ps. you don’t need a Mac to do video editing.
    Color Grading presets for After Effects, Premiere, etc., plus free presets and more.
    LITTLE BLACK BIRD – PROFESSIONAL VISUAL EFFECTS
    https://www.littleblackbird.com
    https://www.myr3d.com
  • Warrick Heever
    January 8, 2009 at 6:31 am
    Thanks will give it a bash tonight and check the quality. I am wanting to composite 3d and green screen.
    I know you don’t need a MAC but I have been using Final Cut pro. P.C. seems to be its own beast. I wish they would bring out Final Cut pro for PC, Macs are mostly P.C these days anyhow. Maybe they will release OS for p.c.
    Thanks for your help it is appreciated
