Activity Forums Adobe Premiere Pro Export H.264 with source timecode
  • Export H.264 with source timecode
    Posted by Lauren Quinn on November 3, 2017 at 12:37 pm
    Hi all.
    I’m currently trying to export a H.264 with the source timecode embedded, from Premiere. Whilst I can see the timecode as part of my exported file when I bring it back into Premiere, the client wants to be able to see it in QuickTime. When looking at the file in QT, I don’t get the option for viewing timecode in the drop down at the bottom left, only standard or frame number.
    I’d like to know if t is possible to create a H.264 which retains the TC, and if not, then why not! Thanks.
    John Heiser replied 8 years, 9 months ago 4 Members · 4 Replies
  • Pierpaolo Ferlaino
    November 3, 2017 at 1:35 pm
    In my experience, when you export from Premiere:
    h264 / .mp4: Premiere reads the embedded timecode, other editing apps don’t
    h264 / .mov: Premiere and other editing apps read the embedded timecode
    QuickTime doesn’t read the timecode from h264 files both in a .mp4 or a .mov .wrapper.
  • Tero Ahlfors
    November 3, 2017 at 1:58 pm
    Use a format that has a TC track or burn in the timecode.
  • Lauren Quinn
    November 3, 2017 at 2:06 pm
    Thanks for your input. When trying to export h264 via the QuickTime format to get it as .mov, I get “exporter returned a bad result, error code 27”. Is there something else I need to do?
  • John Heiser
    November 7, 2017 at 8:26 pm
    You can add a TC track to movies that don’t have them. Here’s a terrific app for that:
    https://www.videotoolshed.com/handcrafted-timecode-tools/qtchange/
    John
