Activity Forums Adobe Illustrator export groups to Photoshop layers
  • export groups to Photoshop layers
    Posted by David Tannenbaum on February 15, 2011 at 7:44 pm
    First: I don’t really know how to use Illustrator. I have Illustrator CS. Someone gave me a file that only has one layer but contained within that one layer are many, many groups. Is there a way to export, to Photoshop, those groups as individual layers? Preferably one PSD file with many layers.
    Les Nemeth replied 15 years, 7 months ago 3 Members · 3 Replies
  • Les Nemeth
    February 16, 2011 at 6:31 am
    That’s a problem right there.
    Well, I don’t remember what CS have – since that’s a tad old, but maybe this workflow remained the same (I’m on CS4 and CS5). Anyhow…
    1. First ungroup all groups. You may have to repeat the Ungroup command a couple of times depending on how they are grouped. If there are elements that you DO NOT want to have separate layers assigned in PS, then do not ungroup those.
    2. Click/select (hilite) the very topmost layer.
    3. In the Layer’s palette popup menu select “Release to Layers (Sequence)”. This will group every individual object/shape into a group. And every group will be a separate layer in PS.
    4. Now File > Export > PSD
    Now you should have each item/element that was in a group on a separate layer.
  • Christina Rodriguez
    February 16, 2011 at 11:36 pm
    I have this archaic version.
    Go to FIle >Export. Select PSD or Photoshop
    then in options select write layers. make sure all of the boxes are checked (except maybe embed ICC profile). Make sure to choose the correct resolution.
    Thant should work.
    C.R.
  • Les Nemeth
    February 17, 2011 at 11:49 pm
    This will not work if you want to preserve groups as layers. It will only preserve layers as PSD layers.
