Activity Forums Media 100 Export function crashes: Producer 13.0.4
  • Export function crashes: Producer 13.0.4
    Posted by Robert Vandeweghe on September 30, 2010 at 5:09 pm
    Last night I when to export a short program-line edit and after clicking “Export” from the “File” menu, I got the Mac spinning beach-ball for 30 seconds and then M-100 quit. This happen a few more times after relaunching M-100. I then tried going back to a recent project that I was able to export just the other day and tried to re-export that project and the same thing happen, the M-100 application quit.
    I ran “Verify & Repair Disk” – zap the P-RAM and rebooted the Mac. But the problem is still there. I also removed the Media 100 preference folder and relaunch M-100, but still I can not Export.
    Any ideas?
    Robert
    Robert Vandeweghe replied 15 years, 11 months ago 3 Members · 6 Replies
  • Floh Peters
    September 30, 2010 at 6:37 pm
    Do you have installed a new quicktime codec? Anything unusual in your Library->QuickTime folder?
  • Robert Vandeweghe
    September 30, 2010 at 6:57 pm
    Floh,
    Thanks for your response. I have not up dated my QuickTime – I am using Qt v7.6.0.
    I checked out the QT folder in the apps library. The last time that I exported out of M-100 was on 9/14 – Interestingly there are two files in the QT folder from that same date:
    AC3MoiveImport.Component
    and
    SMIQuickTimeExportComponent.component.
    I don’t know if that is unusual or not.
    Robert
  • Floh Peters
    September 30, 2010 at 7:13 pm
    Drag them to the desktop and see what happens. If the app still crashes you can move them back to the Library->QuickTime folder anyway.
  • Robert Vandeweghe
    September 30, 2010 at 7:19 pm
    Floh,
    I dragged the two files from the QT Library folder and then I tried to export my video edit from M-100 time-line and this time it worked!
    Thank you so much! If I can ever be of service let me know!
    Best regards,
    Robert
  • Gregg Michaels
    September 30, 2010 at 7:35 pm
    I can confirm that SMIQuickTimeExportComponent.component causes many issues with the export process in Media100 of old and new. It gets installed with Sorenson Squeeze. I have passed this info along to the support guys, but I don’t know of a resolution other than to remove it from the QT folder.
    GM
  • Robert Vandeweghe
    September 30, 2010 at 7:44 pm
    Floh,
    As I told you, I had exported a video out of M-100 on 9/14. After that I wanted to make a Flash version for the web. I was not happy with the quality of the QT version “flash” so I down-load a trial version of Sorenson Squeeze. I was happy with the quality of Sorenson Squeeze flash and hope the teck-guys can work out the bugs!
    Once again, thanks for your help!
    Have a great day,
    Robert
