Activity › Forums › Apple Final Cut Pro Legacy › Export from time line has no sound
Posted by Jared Hawco on October 17, 2008 at 11:50 pmIm exporting directly from the timeline to tape in FCP. I plug in my camera, put it in vtr mode, set external video to all frames which causes the video to be picked up on the camera. But, I can only transfer video, there is no sound, I have tried setting the audio playback to “Audio Follows Video” but this still wont work. Any ideas??
Walter Biscardi replied 17 years, 10 months ago 3 Members · 2 Replies -
Shane Ross
October 18, 2008 at 12:48 amShane’s Stock Answer #8: External Monitor Viewing
If you are working with DV, this is simple. First connect your computer to a camera or deck via firewire, Then connect the camera/deck to your TV/Monitor via RCA or S-Video.
Then start up your camera and tv, then open fcp.
Go to the View Menu, choose > External video > all frames
VIEW>Video playback should be Apple firewire NTSC (If you are using an NTSC set)
VIEW>Audio playback should be Audio follows VideoTechinially, this should send synched video to your TV
If for some reason you can’t view your timeline on your external monitor, there are a few things to try:
1) Make sure that the camera/deck is connected and powered on BEFORE you open FCP.
2) In the Final Cut Pro menu select AUDIO/VIDEO Preferences and make sure your signal is being sent out thru Firewire DV.
3) Go to the menu and select VIEW>EXTERNAL>ALL FRAMES.
4) Click in the % box above the image and select FIT TO WINDOW.
5) Go to VIEW->refresh A/V devices
6) Make sure the Log & Capture window is closed
If you want it to play in both the canvas and the external monitor you need to go to the FINAL CUT PRO menu and select AUDIO/VIDIO settings and make sure MIRROR ON DESKTOP is selected under the PLAYBACK OUTPUT section.
If you are working with HDV footage, FCP 6 allows you to view this via firewire, but ONLY as downconverted DV. It won’t look the best, but you can see it. To do this,
If you need to view any format other than DV at full resolution, then you need to look into capture cards. Several standard definition and high definition models are available from http://www.aja.com and http://www.decklink.com. With these options you’ll need a proper monitor to view full broadcast colors, but all models allow for realtime standard definition downconvert, allowing you to view HD on an SD monitor.
The Matrox MXO is another option that is output only, but allows you to view your footage on an Apple Cinema Display at full broadcast quality.
Shane
Read my blog, Little Frog in High Def -
Walter Biscardi
October 18, 2008 at 12:54 am[Jared Hawco] “Im exporting directly from the timeline to tape in FCP. I plug in my camera, put it in vtr mode, set external video to all frames which causes the video to be picked up on the camera.”
Shane has given you the answer, but please learn the correct terminology.
Exporting from the timeline is to create a media file. Usually a Quicktime Movie. It does not involve a VTR or any sort of recording to video tape.
Record to Tape / Edit to Tape / Layback to Tape is what you’re doing. This is something completely different.
Thank you.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
