Activity Forums Adobe Premiere Pro Export from Premiere keeps failing…
  • Export from Premiere keeps failing…
    Posted by Mark Pybus on August 27, 2009 at 10:35 pm
    Hi There,
    I’m exporting an HD sequence from Premiere Pro and it keeps failing. It will go through the entire export process once the render queue is activated; however, the destination file size doesn’t change from 0kb. Once the render finishes, the file is still 0kb.
    Can anyone help out with this issue?
    G5 Dual 1.8, 1.5GB RAM
    Michael Lorushe replied 16 years, 12 months ago 2 Members · 1 Reply
  • Michael Lorushe
    September 1, 2009 at 9:41 am
    Hi Mark,
    Are you sure Premiere Pro has a render queue feature? I know After Effects does but Premiere?
    Have you not tried just using the Export feature?
    Mike
    Michael Folorunsho
    Clicktone Media
    http://www.youtube.com/clicktonemedia
