Activity › Forums › Adobe Premiere Pro › Export from PP not good enough
  • Export from PP not good enough
    Posted by Brett Clancy on November 30, 2016 at 1:50 am
    After tips about exporting some GoPro footage, that was editing on PP. Sequence setting were AVCHD 1080P – 59.94fps, square pixels, 1920-1080. The exported sequence is not as sharp as timeline sequence. I exported using highest match source -high bit rate, but doesn’t look as good as it could. I’m think I perhaps should have selected a better sequence setting rather than let PP decide when you drag your first edit into timeline ..?
    Joe Barta iv replied 9 years, 10 months ago 3 Members · 3 Replies
  • Vince Becquiot
    November 30, 2016 at 3:31 am
    Hi Brett,
    Uncheck every single match source box and create your own settings. Start with 20Mbps/CBR progressive. How does it look?
    Vince Becquiot
    Indigo Live | Kaptis Media
    San Francisco Bay Area
  • Brett Clancy
    November 30, 2016 at 4:27 am
    Thanks for those tips. I think it does look better. I was also curious about exporting FPS – normally I export 25fps by default, but as this vision was shot in 59.95, I wondered if I should export it as that rate or bump it up to 60, for no other reason than 60 seems a firmer number. LOL my enduring lack of tech knowledge.
  • Joe Barta iv
    December 2, 2016 at 3:11 pm
    If it was shot at 59.95 then export as 59.95,
    you gain no advantage by making it 60fps.
    Joe
    Living the SuiteLife!
    Stuff for editors http://www.cafepress.com/suitelife
    http://www.facebook.com/pages/SuiteLife/1524456414462851?ref=hl
