Export from FCPX for HyperDeck Shuttle 2 playback
I want to be able to use my HyperDeck Shuttle 2 as a playback device for projects created in FCPX. If I make a master file in the right format (Quicktime, ProRes 422 HQ) and follow HyperDeck’s naming convention (Capturexxxx), I can get the files to play back but I cannot get audio to play.
Apparently, the HyperDeck will only playback the file if it has 16 channel audio. BMC acknowledged this as a bug in February, but there is still no fix.
I was able to use “roles” to wrestle 16 channels of audio out of FCPX, but it turns out there is a difference between 16 discrete channels and 16-channel audio.
What I have: https://www.dropbox.com/s/37c8m1e302vggpn/Screen%20Shot%202013-12-26%20at%206.59.13%20AM.png
What I need: https://www.dropbox.com/s/jjq7do04q7qa96q/Screen%20Shot%202013-12-27%20at%2010.02.52%20AM.pngHoping someone has an idea how to create a file that the Shuttle will like.
