Activity › Forums › Apple Final Cut Pro Legacy › Export from FCP to P2 card
  • Export from FCP to P2 card
    Posted by Peter Wiggins on May 24, 2007 at 1:08 pm
    All,
    I’ve come across a company that has written an file menu plugin that lets you export from FCP back to a P2 card.
    Is anybody else interested in using this? I can see it working for news companies etc but I thought I’d see if other people would be interested in purchasing it.
    You could use it to backup, consolidate etc etc BTW I don’t think it will be expensive, but I don’t know how much it will be.
    Peter
    Peter Wiggins replied 19 years, 4 months ago 3 Members · 5 Replies
  • Richard Martz
    May 24, 2007 at 3:11 pm
    Let’s see if I get this right… You are considering using a $900 P2 chip for back up?
    Richard Martz
    MagicMartz Media
    Final Cut Pro HD
    Kona LH
    After Effects
    PhotoShop
    Illustrator
    Lots of other Fun Stuff!
  • David Roth weiss
    May 24, 2007 at 3:26 pm
    Peter,
    Someone here mentioned that FCS2 can write back to P2. I can’t verify that personally, but you might want to check out the release notes.
    David
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • Peter Wiggins
    May 24, 2007 at 4:46 pm
    [David Roth Weiss] “Someone here mentioned that FCS2 can write back to P2.”
    Ok, can somebody confirm this? I don’t use P2 so I don’t know
    Peter
  • David Roth weiss
    May 24, 2007 at 5:11 pm
    Peter,
    I found the following in the FCP 6 Working With High Definition and Broadcast Formats manual on page 93 https://manuals.info.apple.com/en/FCP6_HD_and_Broadcast_Formats.pdf
    Using Print to Video to Output to P2 Cards in the AG-HVX200
    You can output footage in Final Cut Pro to P2 cards in a Panasonic AG-HVX200
    camcorder. This method only works when using the built-in FireWire port on your
    computer in conjunction with the Print to Video command or when playing footage
    directly in the Viewer or Timeline.
    To output to P2 cards, the following must be true:
  • Peter Wiggins
    May 25, 2007 at 9:49 pm
    Yeup but you cannot put it back on the card without the camera
    Peter
