Activity › Forums › Apple Final Cut Pro Legacy › Export from FCP at the same time as compress in Compressor…
  • Export from FCP at the same time as compress in Compressor…
    Posted by Lucy Moon on April 1, 2011 at 5:48 pm
    I often export out of FCP at sequence settings / self contained QT before sending that file to Compressor for a web version.
    What I wondered was, is it a bad idea to have compressor working on files at the same time as export from FCP?
    I’ve got loads of sequences to do today and I wanted to start Compressor before the FCP batch has finished.
    Cheers
    ~Astrid
    MBP 2.2 GHz intel core duo
    2GB ram
    GeForce 8600M GT
    10.4.11 + FCP 6.04
    Chris Wiggles replied 15 years, 6 months ago 2 Members · 1 Reply
  • Chris Wiggles
    April 2, 2011 at 6:27 pm
    I don’t know if that is possible, but you can send the file directly to compressor, skipping the render out to quicktime step.
    I have never had luck doing this on my machine, and I like an archived version of the finished project before compression so I’ve never bothered to do it that way, but you should give it a whirl.
    Regards,
    Chris
