Activity › Forums › Apple Final Cut Pro Legacy › Export from FCP 7 in sync on Mac but not on PC
  • Export from FCP 7 in sync on Mac but not on PC
    Posted by Richard Lee on September 15, 2012 at 9:11 am
    Hi
    Exported a DVPAL sequence from FCP7. This plays fine on the Mac but on a PC the audio is out of sync.
    Any ideas on a possible cause?
    Jeff Meyer replied 14 years ago 2 Members · 3 Replies
  • Jeff Meyer
    September 15, 2012 at 2:19 pm
    If you’re uisng a long GOP codec (any member of the mpeg4 family – H.264 included – or any member of the mpeg 2 family) try using an all I frame codec – DV, ProRes, or Animation.
    Run updates on the PC. Look for updates to Quicktime, the video board, and the audio board.
    If it’s a slower computer try to stick to viewing it at 100%. Any other size involves scaling.
  • Richard Lee
    September 15, 2012 at 2:20 pm
    Thanks, it is exported as DVPAL which is not long GOP. Also, I have tried viewing on several PCs and it is out of sync. I think there is a problem with the file but not sure what?
  • Jeff Meyer
    September 15, 2012 at 2:28 pm
    Might give ProRes or Animation a try. If you do animation consider using AVI instead of Quicktime. In FCP you can use File -> Export -> Quicktime components to create AVI files.
