Activity › Forums › Media 100 › Export from Edit Suite
  • Export from Edit Suite
    Posted by Bob Karsner on January 2, 2007 at 12:00 am
    I am attempting to export from the edit suite on a M100 HDe using the Window Media exporter. No matter what configeration I set, preset or custom, I receive a paramert error from the M100 software.
    Is there an additional plugin or software I need in order to export using the Window Media settings?
    I have clients that use wmv files.
    Bob
    Kieran Matthew replied 19 years, 9 months ago 2 Members · 1 Reply
  • Kieran Matthew
    January 2, 2007 at 2:15 pm
    Hi Bob,
    This does seem to be a bug at present. The work around is to export as a “by reference” file and then use either quicktime pro or a package like streamclip to handle the conversion.
    Hope that helps
    K
