Activity Forums Adobe Premiere Pro export frame size problem
  • export frame size problem
    Posted by Maarten Vanhoucke on February 8, 2009 at 2:03 pm
    I am working on a project with normal DV footage and have encountered the following problem:
    I have adjusted the project settings correctly as far as i know, to match my source clips, which is DV pal widescreen, with pixel aspect ratio of 1.422.
    Whenever I export, I get files with a ratio of 1.067 (even if i try exporting in square pixels or any of the other ratio, and even in the adobe media encoder)
    Why is that happening, and how can i make my exported files get the right ratio?
    Eddie Lotter replied 17 years, 6 months ago 2 Members · 8 Replies
  • 8 Replies
  • Eddie Lotter
    February 8, 2009 at 3:11 pm
    Please post a screen shot of your project settings, your clip properties and the video export settings.
    Cheers
    Eddie
  • Maarten Vanhoucke
    February 8, 2009 at 5:37 pm
    here they come, i have also added images of the source clip and the exported result
  • Eddie Lotter
    February 9, 2009 at 12:52 am
    Do not use the cinepak codec and remove the check from the “Recompress” checkbox.
    Does the program monitor look the same as the exported result? Also, is the program monitor set to “Fit”?
    Cheers
    Eddie
  • Maarten Vanhoucke
    February 9, 2009 at 1:49 pm
    It works for uncompressed microsoft avi’s, which is already some kind of breaktrough! Thanks alot.
    Still I get the same pixel aspect ratio (1.067 instead of 1.422) problem as before when exporting still frames as bitmaps, tiffs or Targa eventough using the same settings. (DV, 1.422, 16/9)
  • Eddie Lotter
    February 9, 2009 at 2:41 pm
    You didn’t answer my last two questions. They are important.
    Cheers
    Eddie
  • Maarten Vanhoucke
    February 9, 2009 at 2:55 pm
    The answer to both questions was yes
  • Maarten Vanhoucke
    February 9, 2009 at 3:29 pm
    I have just upgraded quicktime to 7.6 and now the QT exports work just fine, so i guess that must have been the problem all along…
    Thanks for your support and advice!
    Maarten
  • Eddie Lotter
    February 9, 2009 at 5:02 pm
    [maarten vanhoucke] “Thanks for your support and advice!”
    You’re welcome. Happy editing. Happy editor
    Cheers
    Eddie
