Activity › Forums › Adobe After Effects › export format
export format
Posted by Deleted User on May 15, 2008 at 3:23 pmhi
can you tell me if I want to save high-resolution video is it ok the codec H264 please?(its for a completion,and if i try soroson or animation codec it make some parts pixeleted )
Deleted User replied 18 years, 3 months ago 3 Members · 4 Replies -
Simon Bonner
May 15, 2008 at 3:53 pmH.264 is a delivery codec and therefore highly compressed. You can tweak the settings to get the level of compression you want, though you may be better off compressing from a dedicated compression programme like squeeze. If you’re going to be processing the clip again (i.e. sending to DVD), you would be better off using a lossless codec, like animation set to 100%.
Simon Bonner
youtube.com/simonsaysFX -
Deleted User
May 15, 2008 at 4:10 pmthanks,but the animation codec makes some parts of my work to freeze .do u think i can use ,(when exporting the file) NONE from the options in quick time?(it makes the file like 700 mb but at least dont have any problems when showing…
Erik Pontius
May 15, 2008 at 4:25 pmThe QT animation lossless codec creates files with an incredible amount of data. Attempting to play the files might result in some playback problems as your computer’s CPU and hard drive may struggle to play it smoothly.
Export out of AE using QT Animation to preserve the quality. Then use a dedicated compression program (soreson, etc..) to compress the QT animation file to a delivery format (h.264, etc..) that can be played back from your computer. -
Deleted User
May 15, 2008 at 4:33 pmthanks.but when i send the file as a DVD to the completion, will there be any difrece if i save as :Animation codec or None codec?
dedicated compression program (soreson, etc..) to compress the QT animation”thanks
