Activity Forums Apple Final Cut Pro Legacy Export for Projector NEC VT59- standard projector size
  • Export for Projector NEC VT59- standard projector size
    Posted by Michelle Orpe on August 21, 2011 at 10:58 am
    Hi Guys
    I am about to export a project I have made consisting of photo’s and a motion template. I am putting it onto disc and that disc will be played on a Sony PC to a projector NEC VT59- standard projector size
    Can anyone tell me the best settings & codec to export it, I’m worried as I have a Mac that the DVD won’t work in a Sony PC
    Thank you so much
    Michelle
    Michelle Orpe
    http://www.michelleorpe.com
    Michelle Orpe replied 15 years, 1 month ago 2 Members · 4 Replies
  • Rafael Amador
    August 21, 2011 at 12:12 pm
    Hi Michelle,
    That’s an SD projector.
    Up to Google:
    Accepted Video signals
    PAL/PAL60/NTSC/SECAM/NTSC4.43/PAL-N & M
    [Michelle Orpe] “Can anyone tell me the best settings & codec to export it, I’m worried as I have a Mac that the DVD won’t work in a Sony PC”
    DVDs are all the same (MPEG-2 video) and they should play in every computer, although some particular computers have problems with some brans of disks.
    Make a plain NTSC DVD and try it in a domestic player. If its plays there, your DVD is OK.
    You can’t do much if some computers reject the disk, then there is a problem with the PC, not with your DVD.
    rafael
    http://www.nagavideo.com
  • Michelle Orpe
    August 21, 2011 at 1:10 pm
    Yes, and I am working in PAL, just wondering if I should export in H.264 or DV PAL or Apple Pro-Res or any of the other millions of options 🙂
    Michelle Orpe
  • Rafael Amador
    August 21, 2011 at 3:15 pm
    [Michelle Orpe] “Yes, and I am working in PAL, just wondering if I should export in H.264 or DV PAL or Apple Pro-Res or any of the other millions of options :-)”
    OK PAL.
    You can “Send to Compressor..”, or you can export a quality master from FC and compressit with whatever application.
    Export from FC with the lower compression you can: Prores better than DV.
    H264 is for OK for acquisition or delivery but no when you need process or compress again.
    rafael
  • Michelle Orpe
    August 21, 2011 at 8:20 pm
    Thank you so much, I now think I understand, the DVD is made and it works on my mac, on an old PC I just tried it in and in the TV DVD Player woohoo
    Michelle Orpe
