Activity Forums Compression Techniques Export for flash compression
  • Export for flash compression
    Posted by Jim Mulleder on June 3, 2010 at 7:01 pm
    Hello compression artists,
    I have a client that wants uncompressed files for flash compression to be used in an on-line learning environment. Most of the video is talking heads shot in DV widescreen. My 20 second export out of FCP was 550MB at around 230MB/second, 8 bit uncompressed. I don’t know if we are really gaining anything using such high data rates at 720×486 when this is going down to flash anyway. I know garbage in,garbage out but this seems a little excessive.
    What do you folks use when exporting for Flash video?
    Thanks all,
    Jim
    Jim Mulleder
    Level Horizon Productions
    Cameraman/Editor
    778.888.4336
    Jim Mulleder replied 16 years, 2 months ago 2 Members · 2 Replies
  • Craig Seeman
    June 3, 2010 at 7:12 pm
    You could just export as DV .mov files.
    If they were planing to do any heavy compositing before hand, being in a 4:2:2 format might help but otherwise not really.
  • Jim Mulleder
    June 4, 2010 at 6:20 pm
    Hi Craig,
    I did try your recommendation plus and 8 bit uncompressed, the files were only 3GB. I’ll let them see if they can see the difference.
    Jim
    Jim Mulleder
    Cameraman/Editor
    778.888.4336
