Activity › Forums › Apple Final Cut Pro Legacy › Export for DVDSP4
  • Export for DVDSP4
    Posted by Kcrouch on April 7, 2006 at 12:40 am
    I’m trying to export files from FCE to use in DVDSP4. The files are hugh and DVDSP4 keeps kicking up errors. So I tried exporting the largest QT (32GB) file instead using Compressor and as an mpeg2. It completed 18 or so hours later, but without sound. What do I need to do to get sound?
    Kendall Crouch
    iMac G5 1.8, 1 GB RAM
    Kcrouch replied 20 years, 5 months ago 2 Members · 4 Replies
  • Kcrouch
    April 7, 2006 at 1:51 pm
    Ok. With help from the DVDSP group I found that I need to create a ac3 file, which I found by using Dolby settings. The file created and I imported it into DVDSP. I played the file and had complete silence.
    Help!
  • Captain Mench
    April 8, 2006 at 3:23 pm
    Silly question, but I’ve got to ask…
    Did you load the audio track INTO the track in DVDSP that has the video?
    CaptM
  • Kcrouch
    April 8, 2006 at 11:18 pm
    Yeah. I ended up moving the project back to my iMac G5 (now that it’s had it’s second motherboard replacement). The exported 32 GB QT file was used and DVDSP had no problem. Everything is burning just fine now.
    Kendall Crouch
  • Kcrouch
    April 8, 2006 at 11:21 pm
    I moved the project to my iMac G5 (just had it’s second motherboard replacement) and all worked fine.
    Kendall Crouch
