Activity Forums Apple Final Cut Pro Legacy export for burn dvd NOT using compressor
  • export for burn dvd NOT using compressor
    Posted by Cammie Noel on May 8, 2011 at 7:02 pm
    I cannot use compressor it will not work corrupted or something
    I need the best way to do a test burn for playing a dvd 1 hr 30 min film on an older dvd player. NOT using compressor.I did a few exports but they are all to large to fit on a dvd. Must be under 4.2 GB Thank you…I am using FCP 5 power PC G 5 OSX 10.3.9 : )
    Cammie Noel replied 15 years, 4 months ago 3 Members · 9 Replies
  • 9 Replies
  • Jeff Greenberg
    May 8, 2011 at 9:38 pm
    Do you have iMovie? What comes out of FCP isn’t going to be what goes on the DVD. It has to be an authored MPEG-2 Video TS folder structure.
    If you have iMovie, you can do it on your mac. If you don’t, you’re going to have to fix compressor because it’s the underlying structure for MPEG2 creation along with DVDSP.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Cammie Noel
    May 8, 2011 at 9:47 pm
    I CANNOT FIX COMPRESSOR TOO HARD TO EXPLAIN ANYWAY HOW ABOUT SENDING SOMETHING TO MPEG SStreamclip >?? I have that.
    I DO NOT HAVE IMOVIE. : (
  • Jeff Greenberg
    May 8, 2011 at 9:51 pm
    Cammie,
    I understand and see you’re frustrated. There are always solutions – and forums are just one of them (but at a great price – free! Remember, nobody here is paid, and we’re doing it to help others.)
    I may have a solution for you. You might want to try burn
    It’s an open source DVD burning/authoring application. There seems to be a link for it’s use on a Non-Intel macintosh
    Best,
    Jeff
    P.S. I know you’re frustrated. If something is broken, it needs to be fixed, not worked around. Work arounds are great for today, but really box you in for the future.
  • Chris Tompkins
    May 8, 2011 at 10:37 pm
    You can also import your mov file from FCP into DVDSP and it will create mpeg2 dvd ready files for you. Adjust settings in preferences b/4 import.
    Chris Tompkins
    Video Atlanta LLC
  • Cammie Noel
    May 9, 2011 at 12:26 am
    I did try to fix compressor and could not…
    anyway thanks
    I did try burn last night and it burned the dvd but it was bad …didnt work …I will try it again
    Thank You!
  • Cammie Noel
    May 9, 2011 at 12:59 am
    I just bought imovie (Ilife)from Amazon…should be fine when i get that ; D Thanks
  • Jeff Greenberg
    May 9, 2011 at 1:01 am
    Cammie,
    I hope you bought the older one! The current one won’t work on your system.
    Best,
    Jeff G
  • Cammie Noel
    May 9, 2011 at 1:16 am
    hehheeh…Well i hope i’m not that stoopid ; } yes i did read the system requirements i bought )’9 version ; D Thanks!
  • Cammie Noel
    May 9, 2011 at 1:18 am
