Activity Forums Apple Final Cut Pro Legacy Export for best/full quality (uncompressed)?
  • Export for best/full quality (uncompressed)?
    Posted by Charles House on September 15, 2010 at 3:16 pm
    I’ve been using export to quicktime with current settings to export stuff uncompressed, as that’s what someone here told me. I’ve been sending various footage out to FX guys to have them alter the image and return it to me, so I need it at the highest quality. However, I had an FX guy come over and grab some footage, and he exported it using quicktime conversion, animation settings, and best quality, and it was better quality than what I presumed was the “highest.” Anyway, what IS the best way to export full quality to have someone else edit the image and return it to be dropped back into the timeline?
    Charles House replied 15 years, 12 months ago 3 Members · 4 Replies
  • Jerry Hofmann
    September 15, 2010 at 5:37 pm
    The settings he used are very high quality, however I don’t believe you can improve on the settings you’ve been using. He likely needed that format for the software and hardware he’s using, and not because it’s “better”. It’s not… it’s just cross platform. You can’t improve anything by converting it to another format. The original recording is as good as it will ever be (setting aside color correction).
    You can’t add information that wasn’t originally recorded is what I’m saying.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Charles House
    September 15, 2010 at 5:59 pm
    Yes, I understand that, thank you. However, the quality of his export (same file type, mind you, an .MOV) is clearly better quality, which leads me to believe the method with which I’ve been exporting ISN’T full quality, and IS compressed. But you’re telling me it IS full quality, however he is somehow getting a better quality export?
    He’s using Motion/After Effects, both for Mac, and I’m using Final Cut.
  • Chris Tompkins
    September 15, 2010 at 6:51 pm
    You didn’t mention your original codec – but exporting uncompressed is fine. You doing it the best u can now.
    If you sent him 1 file 8 or 10 bit uncompressed and 1 file Animation codec – u’d be hard pressed to see the diff.
    Chris Tompkins
    Video Atlanta
  • Charles House
    September 15, 2010 at 8:20 pm
    That’s the issue, I am absolutely seeing a difference between the way he exported and the way I exported, going to export with quicktime, current settings (presumably meaning the current camera settings?), and going that way.
