Activity Forums Media 100 export for after effects
  • export for after effects
    Posted by Ernie Geefay on June 22, 2006 at 4:52 pm
    I use to be able to export a media 100 timeline to after effect.
    When I exported out of after effects it would create and xml file that I could open up in after effects 6.5
    I’ve upgraded to after effects 7 and now when I try to import the xml file into after effects, it’s “grey’d out”
    The workaround is to open the xml file with after effects 6.5, save the after effects project…then open it up with after effects 7
    It works but it’s a pain.
    Any suggestions?
    Arthur Dent replied 20 years, 3 months ago 3 Members · 2 Replies
  • Floh Peters
    June 22, 2006 at 4:59 pm
    You need to place the “Media 100 XML Project Importer” in YourAE7Folder->PlugIns->Standard->Format. Then AE7 will take the XML files.
  • Arthur Dent
    June 22, 2006 at 5:26 pm
    You also need to be at 8.2.3a, as that version M100 updated the exporter to be XML, it wasn’t XML in 8.2.2
    ~A.D.
