Activity Forums Adobe Premiere Pro EXPORT Film as RGB24 or YUY2
  • EXPORT Film as RGB24 or YUY2
    Posted by Ninetto Makavejev on May 24, 2007 at 8:44 pm
    I am frame-serving a project to ProCoder to create a Mpeg-2 file and there are 3 possibilities: to export as RGB24, RGB32, and YUY2…
    Now I seem to remember that PremPro natively works in RGB24, is this right? So it would seem that would be best… But then again I think I’ve heard that YUY2 colour-space offers other advantages…
    or is it all just splitting hairs/who-care-if-it-works?
    The original material was SD…
    So could one of the rocket-scientists give me the low-down on the extra-special best-way-to-go?
    thanks and
    greetings,
    ninetto
    Ninetto Makavejev replied 19 years, 3 months ago 2 Members · 2 Replies
  • My guess only, but as MPEG 2 is y cb cr the least amount of re-sampeling you do to the y channel, the better. I would choose the YUV24 out of premiere. Are you using the Pro coder plug in from within Premiere? The other option would be to test a couple of samples using a couple of gradiated ramps with separate luma and chroma characteristics, and maybe add some moving grid lines in Premiere. You could make the elements it in PS easily.
  • Ninetto Makavejev
    May 29, 2007 at 5:42 am
    Thanks for the post, Gene.
    I will give the tests you suggested a try. I am using ProCoder 2 which doesn’t have a plug-in for PremPro 2. I guess version 3 must have one, but I don’t know what an upgrade will cost.
    So I am using an open-source frame-server.
    When/if I have results, will post back.
    best regards,
    ninetto
