Activity Forums Apple Final Cut Pro Legacy Export FCP sequence to QuickTime crashes
  • Export FCP sequence to QuickTime crashes
    Posted by Steven Escobar on April 19, 2011 at 6:30 pm
    I’m trying to export my final output to a QuickTime but it’s actually crashing on me at around 80% finished after more than 10 hours. I’ve tried to export the
    Audio then create new sequence and nest the
    Video track into new sequence but it still crashes. Meaning it goes to the window that says would you like to transmit error log to apple kinda thing.
    My project file is 131megs and I have 6gigs of memory. Is there a limit to a FCP project? All I have in the
    Project is the sequence and have deleted any extra folders and files.
    Does anyone know if there’s another way I
    Could do an export?
    I’m trying to accomplish a few things:
    1) I’d like to export to compressor to watch on apple tv.
    2) make a blu ray disk
    3) output final master QuickTime.
    I’m in desperate need since I have a
    Screening on May 7th.
    BTW, ignore my computer hardware setting that appear u under. I don’t use that system any linfer.
    Steven Escobar
    G4 1.25MHz Dual MDD
    1.25 RAM
    IgniterX RT w/component
    QT 6.04
    OS X.2.8
    FCP 4.1
    Med
    Gary Askham replied 15 years, 4 months ago 4 Members · 5 Replies
  • David Roth weiss
    April 19, 2011 at 7:11 pm
    [Steven Escobar] “I’m trying to export my final output to a QuickTime but it’s actually crashing on me at around 80% finished after more than 10 hours.”
    It’s easy to tell from the 10-hour figure that you are obviously trying to export directly from the timeline in FCP. Dont!!! Instead, export self contained QT using Export>>Quicktime Movie, and use that as your master to create DVDs, web videos etc. from Compressor.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Rafael Amador
    April 19, 2011 at 7:15 pm
    [Steven Escobar] “Audio then create new sequence and nest the
    Video track into new sequence but it still crashes”
    Steven, I don’t know the reason of your problem, but NESTING probably complicates things.
    [Steven Escobar] “My project file is 131megs and I have 6gigs of memory.”
    What means 6GBs memory?
    Footage, or “free memory in your HD”?
    rafael
    http://www.nagavideo.com
  • Steven Escobar
    April 19, 2011 at 7:25 pm
    Yes. That is what I’m trying to so. I tries self contained video as well as reference.
    Steven Escobar
    G4 1.25MHz Dual MDD
    1.25 RAM
    QT 6.04
    OS X.2.8
    FCP 4.1
    Med
  • Steven Escobar
    April 19, 2011 at 7:27 pm
    I have 6 gigs of RAM. So I don’t know if my project of 131 megs is using more than that and the application is running out of memory.
    Steven Escobar
    G4 1.25MHz Dual MDD
    1.25 RAM
    QT 6.04
    OS X.2.8
    FCP 4.1
    Med
  • Gary Askham
    April 19, 2011 at 9:12 pm
    Ah, the joys of working with large, complicated sequences in Final Cut Pro.
    Deleting items from your project doesn’t actually free up that much space.
    What you need to do is create a new project and drag your final sequence into the new project.
    I would be tempted to then trash all your render files and start a fresh render – setting the render drive to the fastest drive you have available. This might not happen in one go. Depending on whatever is going on in your project you might find it crashes so you might have to do it in sections, maybe even clip by clip. Once you’re sequence is rendered export a Quicktime movie (self contained or refernce). Then move on to Compressor.
    FCP and Avid Technical Support
    Air Post Production
    Shoreditch – London
