Activity Forums Apple Final Cut Pro Legacy Export FCP Quicktime File make One File and 3 & 4 AV file
  • Export FCP Quicktime File make One File and 3 & 4 AV file
    Posted by Sulaman Hameed on February 14, 2008 at 5:18 pm
    Hello
    I am user FCP last 6 Years but this time I face Very Different Problem.
    I have G5 2.66 GHZ with 2 GB ram 2 Hard drive each 500 GB with FCP 5
    the problem is that when I export FCP Quicktime file in fcp sequence .. create one master file and 4 same name “AV” file ….
    Why create same name “AV” file ..
    I am using also in this project Westren Digital USB 2 External Hard Drive and all footages and Project also in this external USB Hard Drive ….
    Plz help me out
    Sulaman Hameed
    Snr Non Linear Editor
    DawnNews TV
    Pakistan
    Sulaman Hameed replied 18 years, 6 months ago 3 Members · 6 Replies
  • Jeremy Garchow
    February 14, 2008 at 5:20 pm
    Sounds like your hard drive is formatted for fat32 (windows) and you have a 2GB file size limit so FCP is breaking up the files in order to conform for that spec.
    Jeremy
  • Zane Barker
    February 14, 2008 at 5:35 pm
    Also USB hard drives will cause issues when editing, they cannot sustain a constant data rate like firewire can.
    Don’t let technology get in the way of your creativity!
  • Sulaman Hameed
    February 14, 2008 at 5:56 pm
    first of all thanx
    If I reformet USB hard drive then I get what I want meanexport file one piece.
  • Sulaman Hameed
    February 14, 2008 at 5:59 pm
    and If I export first in system Hard Drive Creat single file not “AV” files
    Sulaman Hameed
  • Jeremy Garchow
    February 14, 2008 at 6:03 pm
    [sulaman hameed] “and If I export first in system Hard Drive Creat single file not “AV” files”
    Yes, as it’s formatted for OSX. If you reformat your USB drive, you will lose all of the information on it so be sure to back it up first.
    Jeremy
  • Sulaman Hameed
    February 14, 2008 at 6:09 pm
    Thanx very much … Jeremy
    Yes I first make a backup than Formet OS X
    Sulaman Hameed
