Activity Forums Boris FX Particle Illusion export error: “invalid clipboard format – incorrect data (line 9, near column 0)
  • export error: “invalid clipboard format – incorrect data (line 9, near column 0)
    Posted by Graham Wellington on May 11, 2007 at 10:30 pm
    “After Effects error: invalid clipboard format – incorrect data (line 9, near column 0).”
    My emitter’s position refuses to be exported to AE 7.01 pro. I always get that error.
    I tried with and without the offset check, neither way works.
    I’m using the latest ParticleIllusion demo. I was hoping to buy this program to use in place of AE’s motion tracker on difficult videos.
    Alan Lorence replied 19 years, 4 months ago 3 Members · 3 Replies
  • Elvis Deane
    May 12, 2007 at 4:53 am
    The postion info in AE7 was changed slightly to require a bit of a workaround to move data back and forth between the two programs. This tutorial explains what you need to do.
    Elvis Deane!
    The Apprentice Magician’s Guide to particleIllusion
    Wilbur of Wumbaberry
  • Graham Wellington
    May 12, 2007 at 12:09 pm
    I removed “position” in notepad and now there is no error but when pasting into AE7 it only adds one keyframe at the beginning.
  • Alan Lorence
    May 12, 2007 at 12:32 pm
    When going from pI3 to AE 7, I think you need to add a single word.
    Do this to compare clipboard data produced by AE 7 and pI3:
    – Copy some AE 7 data to the clipboard, and paste it into Notepad.
    – Export position data from pI3 to the clipboard, and paste it into Notepad.
    – Check the differences, and edit the pI3 data so it looks like the AE 7 data.
    Alan.
    http://www.wondertouch.com
