Export Error after PI update
A few minutes ago I updated my particleIllusion version with an update that was avialable by checking.
After installing the update, however, I immediately experienced errors which causes particleIllusion to shut down whenever I try to export PI footage, in order to use it for compositing in AE.
At the moment this turns out to be quite a problem because I have to finish off a music video this weekend which requires some FX rendered in PI & comped in after effects – for now I can bypass this problem by saving the particle projects & rendering them out via ParticleIllusion Render, but it’s not as comfortable as usual…(interestingly enough there’s no such error when I choose to export the PI renders via an *.avi file, however this doesn’t prove to be useful for me because I do the further compositing in after effects… )
If someone else experiences a similar problem, feel free to report here as well,
& when that’s possible – PI staff could you please check as well on this problem ? just in case so that I know if it’s just me or if that’s a generic problem from the update… 😉ADDITIONAL NOTE:
After further reviewing the renders by PI-Render, I noticed some weird render errors of the particles, affectiong especially the particle’s visibility & alpha channel settings. Apparantly the update for ParticleIllusion Renderhad some negative side effects as
I finally reverted the whole update process using the files from the previous one (kudos to that one; it was very helpful… ;)), & I was able to continue my work as usual… 🙂
Eclipse FX
https://www.geocities.com/desperate_minds
YouTube keyword: eclipsefx
