Activity › Forums › Apple Final Cut Pro › Export embedded subtitles FCPX
Posted by Guylain Doyle on December 4, 2018 at 10:31 pmHi,
I’ve added english closed caption (ITT) on my spanish interviews in fcpx 10.4.3
I want to export a QT movie for a projection on screen. The problem is when I open the file,
the subtitles are not embedded.I did activate (role) them in the index panel and checked the ITT box at the export stage.
I’m not familiar with closed-caption at all.
Anybody knows what I’m missing?
Andreas Kiel replied 6 years, 3 months ago 7 Members · 35 Replies -
Jeremy Garchow
December 4, 2018 at 11:02 pmYou mean you want the captions burned in to the video (with no way to turn them off)?
This option is available in FCPX 10.4.4 but not 10.4.3.
Andreas Kiel
December 5, 2018 at 6:25 pmITT is for iTunes only and is never embedded.
CEA will be embedded for supported languages.Otherwise follow Jeremy’s advice and upgrade to 10.4.4 and you can get a “poor man’s” burn in.
Spherico
https://www.spherico.com/filmtools\”He who fights with monsters should be careful lest he thereby
become a monster. And if thou gaze long into an abyss, the abyss will
also gaze into thee.\” – Friedrich Nietzsche, Beyond Good and Evil -
Mark Suszko
December 5, 2018 at 8:45 pmI -think- you can do a burn-in. regardless of FCPX version number, if you render it out using Compressor. Worth a shot?
Andreas Kiel
December 5, 2018 at 11:33 pm[Mark Suszko] “Worth a shot?”
Definitively not 😉Spherico
Eric Santiago
February 18, 2019 at 1:37 amI used the latest FCPX to create my ITT files and would like to create an SRT file out of it somehow.
I read up on the YouTube option but is there another way?
And if I were to use Spherico X-Title, will that export the ITT to an SRT? -
Jeremy Garchow
February 18, 2019 at 1:42 amYou can do srt in fcpx, just change the caption role to srt.
Eric Santiago
February 18, 2019 at 1:56 am[Jeremy Garchow] “You can do srt in fcpx, just change the caption role to srt.”
Thanks just figured that. Is there a way to do a mass edit?
I tried selecting them all and dragging it to the SRT channel and FCPX crashes. -
Eric Santiago
February 18, 2019 at 1:58 amI really should leap before I ask here ????
Thanks, Jeremy for getting me started.
Eric Santiago
February 22, 2019 at 3:59 pmI switched the ITT to CEA and it seems to work.
At export, I chose to save as a file.
I don’t recall but does the CC embed as well into the exported clip?
My last CC project was in Premiere.
Many moons ago 🙂 -
Jeremy Garchow
February 22, 2019 at 4:24 pmCEA 608 allows embedded the caption in to the file (closed captions).
The other formats are separate files (ITT & SRT) and do not support embedding in to the file.
You can also burn-in (open captions) all formats as well by hitting the “captions” button in the Role tab of the share window.
Should look something like this:
Jeremy
