Activity › Forums › Adobe After Effects › Export Effects & Presets
  • Kevin Camp
    June 19, 2008 at 4:59 pm
    yes, when you save an animation preset it creates an .ffx file where ever you tell it to create it… i save mine back into the presets folder in the after effects folder (the same folder that contains the application).
    so if i needed to transfer presets, i can just pull them straight from that preset folder to the preset folder on another system.
    you should be able to do the same, you just need to know where you were saved those ffx preset files.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
