Activity › Forums › Apple Final Cut Pro Legacy › Export each audio track as mono?
Posted by Vince Gaffney on February 25, 2007 at 3:30 amI need to export my audio tracks as individual mono tracks for work in Pro Tools. Is it possible? I have channel 1 and 2 checkerboarded to clean up the transitions at the cuts. Every export method I’ve tried gives me a pair of mixed tracks. Seperate AIF’s of each track would be ideal. Any ideas?
Vince
Paolo Mugnaini replied 18 years, 1 month ago 3 Members · 7 Replies -
Arnie Schlissel
February 25, 2007 at 3:31 amLook up OMF exports in your FCP manual. ProTools wants an OMF file from you.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog -
Vince Gaffney
February 25, 2007 at 3:38 amI don’t have digitranslator and was hoping there was a way around it aside from making duplicate timelines and exporting the tracks individually. Is there a way in STP? I have that. I also have 21 versions of these commercials. Thanks.
vince
Arnie Schlissel
February 25, 2007 at 3:41 amYou do not need the digitranslator. You export directly from your FCP timeline. It’s in your FCP manual.
Arnie
Vince Gaffney
February 25, 2007 at 11:16 amIt’s not the OMF export that’s problematic, Pro Tols won’t open it without Digitranslator. I was just looking for an alternative approach. Thanks
vince
Arnie Schlissel
February 25, 2007 at 6:35 pmSorry, I didn’t understand you. Without the digiTranslator, I think the only other option to get discrete audio files into the ProTools timeline is to give your mixer an audio EDL & the tapes with original audio on them so the mixer can digitise the audio himself.
Arnie
Vince Gaffney
February 25, 2007 at 8:26 pmthx. i found a way with quicktime conversion to export aif’s of each track. they’re actually for me so i can do a rough mix for the client.
vince
Paolo Mugnaini
August 11, 2008 at 12:21 amHi,
Could you please tell me how you can export AIF mono files? I have tried and they’re still 2 tracks and I have a timeline with 6 audio tracks, 2 stereo but the rest mono. What am I doing wrong?
thanks
PaoloFCP 5.1.4 – PowerMac 2.2 Dual – 4.5 Gb Ram
1Tb G-Raid2 – 2 1Tb Lacies
