Activity › Forums › Adobe Premiere Pro › Export Dolby Digital 5.1
Posted by Giannakis Omirous on November 19, 2012 at 7:16 pmWhat is the best way to export an HD video with Dolby Digital 5.1 encoding from Adobe Premier cs5 for a TV playback. I have tried the H.264 Blu Ray export ‘Dolby Digital’ but there was a problem since i didnt have a surcode encoder. Isnt there another way?
Angelo Lorenzo replied 13 years, 10 months ago 3 Members · 3 Replies -
Robert Brown
November 21, 2012 at 11:58 pmDolby 5.1 can be tricky because you have to have a Dolby encoder obviously and then it will only playback with an AC3 player. If you are making a DVD or BluRay you can use apple compressor to turn your surround wav files into 5.1 AC3. Then you can use Encore and that can burn the 5.1 and a stereo pair if you want to a BluRay or DVD – you would have to provide the stereo file as another file to Encore.
Compressor I think is the cheapest way to do it and most people already have it.
Robert Brown
Editor/VFX/Colorist – FCP, Smoke, Quantel Pablo, After Effects, 3DS MAX, Premiere Prohttps://vimeo.com/user3987510/videos
Giannakis Omirous
November 24, 2012 at 3:07 pmi already have an ac3 file and i want to embed it in an HD photo in premier. I will playback the video on my TV through a USB (not DVD).
Angelo Lorenzo
November 26, 2012 at 4:48 amYou probably want to look at a command line tool like FFMPEG or FFMBC. On Windows it should be easy, on Mac I think there is a bit of a set up.
Regardless, these free tools will allow you to take the video stream from one file and the audio stream from another. Quality is kept as there is no transcoding… just a merging of the info into one file.
Alternately, if you have Quicktime Pro and you’re working with a MOV file, you should be able to use the program for this function as well.
Angelo LorenzoNeed to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services – Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire – The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
