Activity Forums Apple Final Cut Pro Legacy Export does not match timeline
  • Export does not match timeline
    Posted by Jake Roels on July 31, 2013 at 12:36 am
    I’m editing footage converted from mp4, all footage is now ProRes LT. Sequence is also ProRes LT.
    My exports have clips slid two seconds behind their starting spot. In case I’m not being clear here, the clips cut at the right time but it plays from 4:08 to 4:12 when I want 4:10 to 4:14.
    No clip attributes have been changed.
    Has anyone dealt with this before? I’m baffled.
    Michael Gissing replied 13 years, 1 month ago 2 Members · 3 Replies
  • Michael Gissing
    July 31, 2013 at 12:49 am
    Are you exporting a self contained quicktime mov with current settings or are you using Quicktime conversion?
  • Jake Roels
    July 31, 2013 at 1:51 am
    Self contained with current settings. No conversion.
  • Michael Gissing
    July 31, 2013 at 2:06 am
    Have you done the usual Preference trash, permission repairs routine? If so then is it always a consistent offset on each clip?
    Does source clip timecode match sequence timecode exactly? How did you do the conversion from mp4 to ProRes? Have you tried copy pasting the timeline into a totally new project timeline with a new sequence with matching settings? Possibly a corrupt project or sequence.
    Try editing a few shots into a totally new project and see if the problem is in a specific sequence, project or is in the clips timecode settings.
