Activity Forums Apple Final Cut Pro Legacy Export disaster – avi – .mov to export
  • Export disaster – avi – .mov to export
    Posted by Jennifer Samuel on June 20, 2011 at 6:21 pm
    Hi all,
    I’m in a bit of a bind. I’m exporting a 8 minute sequence which is pretty simple (one video track, two audio plus subtitles) and am getting a host of issues in the exported clips – stutters, large pixelations etc. I am now thinking the problem may be with the original files and how I converted them but I’ll put the details out there so I don’t have to keep on guessing because my troubleshooting thus far has not been successful.
    So – the original files were shot on a vado/flip cam type cameras as well as the canon 5dMII. The files were
    1280 x 720, H264, 30 fps, 44KHz AVI files
    1280 x 720 AAC, 30 fps, 44 khz MPEG files
    960 x 540, H264, 30 fps, 44 KHz MOV files (from Canon 5DMII so much higher quality)
    In order to edit them, most were converted to
    1280 x 720, H264, 30fps/29.97 fps, 48 KHz MOV files
    The Canon 5DMII files were converted to
    960 x 540 Pro Res 422, 48 KHz MOV files
    A files were converted to
    720 x 576, Pro Res 422, 48 Khz MOV files
    A few people have been working on this so I’m not sure why some of these decisions were made. But my problem is that while it playing through ok, when it exports there are major issues.
    Can anyone tell me what I can do at this point? Should I go back to the original files and reconvert them? If so, to what? What are the best settings to work in for a project like this?
    Thanks so much for your help.
    Jen
    Jennifer Samuel replied 15 years, 2 months ago 1 Member · 3 Replies
  • Jennifer Samuel
    June 20, 2011 at 7:14 pm
    I had a feeling that was the case. I kinda always fumble my way around this compression stuff because I’m not very clear on the pros/cons and uses of the different kinds. Is ProRes generally a good format in which to edit these these compressed H264 files? And then recompress them when outputting? Or is there another that you recommend? Thanks for your help.
  • Jennifer Samuel
    June 21, 2011 at 3:21 pm
    Yeah – I’ve used MPEG streamclip before and it’s great. One problem. When I converted the AVI files to .MOVs using MPEG streamclip they had no audio. I used these settings:
    1280 x 720, Pro Res 422, 30fps/29.97 fps, 48 KHz MOV.
    Any idea why that would happen?
    Thanks.
    Jen
  • Jennifer Samuel
    June 21, 2011 at 4:06 pm
    well i used the same settings for the mpeg files and they all had audio so i’m thinking it must be something related the avi files as the source. the audio is selected and whether i convert it to 48 KHz or keep it at 44 KHz the exported .MOV is silent. Anyone know the best way to get around this?
