Activity › Forums › Apple Final Cut Pro › export creates banding
  • export creates banding
    Posted by Jacob Brown on April 1, 2013 at 7:46 pm
    I am trying to export a prores222(hq) video to prores222 (hq). When it plays in final cut there are no banding issue.
    In every export I have done, there is severe banding wherever a transition is. At the beginning of the film, a fade from white transition bands badly on top of a grey background.
    It is frustrating because I keep playing it in final cut and there is no problem.
    I am wondering if there is a setup through compressor I can use to get rid of this problem? I don’t need to be in prores, could go to any high quality format.
    thanks!
    jacob
    Gary Adcock replied 13 years, 6 months ago 3 Members · 3 Replies
  • Loren Risker
    April 1, 2013 at 8:16 pm
    Just curious, are you watching the video in final cut at 100%? Scaling up or down can hide some artifacting.
    OutOfFocus.TV – Original series, music videos, and entertainment for your couch.
  • Jacob Brown
    April 1, 2013 at 8:21 pm
    yup, i’ve watched it full screen, in window, everything. both in FCPX and quicktime and VLC
  • Gary Adcock
    April 1, 2013 at 8:44 pm
    [Jacob Brown] “In every export I have done, there is severe banding wherever a transition is. At the beginning of the film, a fade from white transition bands badly on top of a grey background.
    OK, Jacob.
    FCP sees the ProRes video as 10bit, what ever app you are viewing the file in is only seeing the 8bit ( like the QT player on either platform)
    TURN OFF any realtime processing- all of that in FCP or avid is only 8bit, set FCP to Safe and render the file out to see if it is still there.
    You don’t say what you are playing on or how you are viewing the file, best guest here is that you are not working within the SMPTE spec (density locked btw 16-235) so your whites are too high and your blacks to low to start.
    An easy fix is to process the clips with a bit of noise, 1%-3% is usually enough to clean the image contours.
    gary adcock
    Studio37
    Post and Production Workflow Consultant
    Production and Post Stereographer
    Chicago, IL
    Follow my blog at https://www.garyadcock.com
    Or follow me on Twitter
    @garyadcock
