Activity › Forums › Adobe Premiere Pro › Export crash with project
  • Export crash with project
    Posted by Patrick Morrow on October 4, 2017 at 9:15 pm
    We have tried everything with a certain timeline as it will not export, any other ideas??? We have tried permissions, cache, new project timeline, different codec. It just quits Premier and gives no error message.
    Patrick Morrow
    Eric Merklein replied 8 years, 12 months ago 3 Members · 2 Replies
  • Jeff Coleman
    October 5, 2017 at 9:58 am
    Not sure. What OS and Premiere version?
    Can Premiere export anything, such as a different one-clip timeline in a different project?
    If not, then perhaps it’s not a sequence/project/media issue. If it can, then perhaps it is. Did you try the following?
    1. Create a new sequence. Copy the clips from old sequence into new.. Delete half the clips until you have successfully exported. (Corrupt media file finding routine)
    2. Start a new project. Import that old project into your new. Create a new blank sequence. Copy the clips from old sequence and paste into new. (Corrupt project/sequence fix)
  • Eric Merklein
    October 5, 2017 at 11:17 am
    I had the same problem last week trying to export a 52 gig single QT video file that I recorded, that fed through a switcher to Ninja Blade.
    The original was 1080, and the only way I could export without crashing was to change output setting to 720. Crazy, yes?
    You may also try cleaning your preferences. My system froze up until an Adobe pro took control of my compute and did the deed 2 weeks ago.
    Eric
