Activity Forums Adobe After Effects Export Codec question
  • Export Codec question
    Posted by Marc Lucas on January 18, 2012 at 12:19 pm
    I used to export out of AE by just using the default animation codec, I quickly started exporting as ProRess but when You export as ProRes you don’t get the alpha channel, hope thats right. What other alternative codec, and less file size, would be suitable if I’m going to be using the files in a 720P FCP timeline using a ProRes timeline?
    Marc Lucas replied 14 years, 8 months ago 4 Members · 4 Replies
  • Walter Soyka
    January 18, 2012 at 1:57 pm
    Animation codec can carry an alpha channel (use the Lossless + Alpha output module).
    If you’re working with a ProRes timeline in FCP, you should render to ProRes from AE to avoid having to render in FCP. If you need alpha, consider using ProRes 4444.
    Walter Soyka
  • Hosein Alfa
    January 18, 2012 at 3:54 pm
    1 > lossles with alfa
    2 > Quick time > check item alfa render
  • Andrew Somers
    January 18, 2012 at 8:10 pm
    The prores codecs can be downloaded here:
    https://support.apple.com/kb/DL1396
  • Marc Lucas
    January 18, 2012 at 8:28 pm
    Still on FCP 6 as my working machine haven’t done any project’s on X yet:-)
    So I take it Dave that the Animation Codec is only really big in size when there is next to any transparency in the render opposed to say the PNG option where even though there is transparency the file comparably would be larger than the Animation Codec.
    I’m not fused about having to render anything in the FCP timeline because I only use AE occasionally with one of my current workflows.
    Thanks for the replies!
