Activity Forums VEGAS Pro Export codec from vegas to FCP?
  • Export codec from vegas to FCP?
    Posted by Eric Pautsch on July 31, 2005 at 9:21 pm
    I have a client who works in Vegas. I use FCP. What is the best method to export a .mov file from Vegas to import into FCP? should he export a NTSC DV .mov file or would it be best to just provide the original tapes for me to capture?
    Thanks in advance
    Eric
    Timothy Duncan replied 21 years, 1 month ago 2 Members · 1 Reply
  • Timothy Duncan
    July 31, 2005 at 10:23 pm
    FCP will import Vegas DV AVI files without issues. The difference you will find is with the video levels. Vegas uses video based level mapping into RGB color space and Final Cut uses computer based levels.
    You can adjust with CC in FCP as needed. The best thing to use (if the project is DV) is a DV AVI.
    Side note: I convert FCP projects to Vegas on a regular basis for finishing for many of my clients. Vegas can read all files that FCP can, and can read the files via networking right off of a Mac. To put it simply, Vegas is like running Motion and Sound Track directly in the editing timeline without having to bounce out, and giving far superior sub-pixel rendering much faster.
    td
