Activity › Forums › Apple Final Cut Pro Legacy › Export clips from timeline one by one
Posted by Vasik Greif on July 30, 2009 at 8:44 amHi, I would need to export edited clips from timeline one by one. The footage is XDCamEX1, output format should be h264… Is this possible in FC? Thanks
Vasik Greif replied 17 years, 1 month ago 3 Members · 3 Replies -
Nick Meyers
July 30, 2009 at 9:05 ambest thing is to get the clips into BIN in the browser.
you can then do a batch export.
FIle Menu > Batch Export, or right or control click on the items or binso as not to tie up FCP, the best thing is to simply export as QuickTime Movies.
if there are no effects on the clips, then you can export as NON-SELF CONTAINED, or REFERENCE movies.
then take those files and run them though compressor.if the clips are layered, or have rendered effects on them this is what to do:
make a COPY of your sequence, put it in a new bin.
go though the copied sequence defining the bits you want to export, either with in/outs (park on a clip, hit X), or by selecting.
make a NEST of this selection (option C)
name the nest, hit OK,
and it will appear in the bin along with the sequence.when done, batch export as above.
cheers,
nick -
Todd Beabout
July 31, 2009 at 1:34 amIn your timeline, select all the clips and drag them into a new bin. Now just use Batch Export to kick them out individually.
It will use the in/out points from the clips as they are in the bin.
Todd Beabout
Freelance Director/Editor
Los Angeles -
Vasik Greif
July 31, 2009 at 6:07 am
