Activity Forums Apple Motion Export Chroma key with Alpha
  • Export Chroma key with Alpha
    Posted by Chris Jenkin on May 15, 2008 at 2:06 am
    I have to send a person shot on blue screen to a client on a transparent background. They want to place it on a website and don’t have the ability to key out the blue hence wanting it to be exported with a key channel. I’m working in PAL SD 8 bit uncompressed. The key works fine and when I turn the canvas bg to transparent from the sub menu I can see a nice clean key. I’ve turned off all layers not invloved with the key and export it as uncompressed with colour+alpha selected. When it renders out I can see it keyed over black even though there is no black in the project. When I bring it in to FCP the doesn’t seem to be a key channel even if I select it in the bin menu. So all see is my blue screen person keyed over back as a solid layer rather than containing a key channel. What am I missing, is the probelm in FCP or doesn’t motion export an alpha channel if you are doing a chroma key. If that’s the case any suggestions.
    Eddie Adyr replied 16 years, 8 months ago 4 Members · 3 Replies
