Activity Forums Apple Final Cut Pro Legacy Export by reference
  • Export by reference
    Posted by Mike Raff on June 21, 2012 at 10:05 pm
    I confess, I’ve never really understood this. I mean, I get the idea: you’re exporting pointers to the actual media, not the media itself and that’s supposed to result in a much smaller file. But I must not understand how to do it.
    For example, I select a sequence and go File>Export>QuickTime Movie and
    Setting: Current Settings
    Include: Audio and Video
    Markers: None
    and leave both the Recompress All Frames and Make Movie Self-Contained checkboxes UNCHECKED.
    Is that not the correct method?
    I’ve done it that way and also tried it with the Make Movie Self-Contained box checked and both files came out precisely the same size.
    What am I missing?
    TIA,
    Mike Raff
    Richmond, VA
    Kylee Pena replied 14 years, 3 months ago 5 Members · 5 Replies
  • Michael Cheung
    June 22, 2012 at 7:04 am
    It’s a different type in the export menu. In the drop down list where it’s says send to quicktime or something, there should be a quicktime reference movie option.
    Michael Cheung
  • David Eaks
    June 22, 2012 at 8:40 am
    I export reference movies from FCP7 all the time, with regular export (cmd-e) and simply leaving self-contained unchecked. Not sure why it isn’t working for you.
    I wasn’t even aware of any reference movie option under QuickTime Conversion, sure that’s not Avids menu you’re thinking of?
  • Michael Cheung
    June 22, 2012 at 8:54 am
    That’s exactly what I’m thinking of. Can you tell which I’ve been using recently!
  • Rafael Amador
    June 22, 2012 at 9:15 am
    That’s the correct method, being the sequence fully rendered.
    If is not working, try refreshing FC preferences.
    rafael
    http://www.nagavideo.com
  • Kylee Pena
    June 22, 2012 at 1:26 pm
    Is your sequence unrendered?
    blog: kyleesportfolio.com/blog
    twitter: @kyl33t
    demo: kyleewall.com
