Activity Forums Adobe Premiere Pro Export by Adobe MPEG Encoder extremely slow
  • Export by Adobe MPEG Encoder extremely slow
    Posted by Michael Alexander on April 22, 2005 at 10:40 am
    Hi there,
    Sorry, this is a question concerning Prem 6.5:
    I cannot export a project due to the extremely slow exporting rate.
    For a one hour project estimated time is about 20 DAYS (more than 15 seconds per frame)!
    My PC is new (XP Pro, 3.4 GHz, 1 GB RAM, 200 GB free Diskspace)
    Adobe Encoder 1.2 installed, disk defragmented,
    project settings and export settings are the same, I use the standard settings f
    Michael Alexander replied 21 years, 3 months ago 2 Members · 4 Replies
  • Mike Velte
    April 22, 2005 at 11:24 am
    Unless you have Magic Bullet effects applied, your render should be in almost real time. Try updating to 1.3 from Main Concept.
  • Michael Alexander
    April 22, 2005 at 11:45 am
    Hi Mike,
    as I am using the German version of Prem 6.5 (and have the German version of MPEG Enc 1.2 installed too), does the english version of MPeg Enc 1.3 go with it, or may occure problems?
    Thxs
    Michael
  • Mike Velte
    April 22, 2005 at 8:25 pm
    As you can read both languages, give it a try.
  • Michael Alexander
    April 25, 2005 at 9:14 am
    Hi Mike!
    I tried to encode the project with version 1.3 but no change at all. It did not work.
    But then I tried the new possibility to export the timeline as “film” and using the MPEG Encoder there and did the same settings as I would do with exporting the timeline the usual way and it works perfectly!
    So for me, there is no further need to export via “Adobe MPEG Encoder” , I will do that the “new way” and use the version 1.3 that way.
    Regards
    Michael
