Activity Forums VEGAS Pro Export and import transport stream M2TS
  • Export and import transport stream M2TS
    Posted by Marius Dudu on August 10, 2024 at 1:24 pm
    Hello All !
    I want to achieve the workflow described below.
    I am transferring MTS files (1080i60) from Handycam and start editing them in Premiere.
    In Premiere I am using some effects which are not available in Vegas.
    Once the edit is done in Premiere, how can I export into the same format MTS/M2TS files ?
    I read somewhere that Dolby encoding has been removed in Premiere, meaning that it will not output MTS/M2TS anymore. If such case, what is the most suitable format (audio + video) to export from Premiere and to import into Vegas – I am talking here about 1920×1080 interlaced video.
    In Vegas, I am using plugins which are better compatible with interlaced video.
    So, I want the video files treated in Premiere, to import them into Vegas and from Vegas to have the final output.
    Thank you
    Hector Vera replied 2 years, 1 month ago 2 Members · 3 Replies
  • Hector Vera
    August 12, 2024 at 4:40 pm
    I would say that the best format I use for Vegas Pro since I edit videos there all the time are between .MOV and .MP4 formats via 59-60fps and 1080p format. Not sure if you are looking for higher quality than that. I looked up this link right here: https://community.adobe.com/t5/premiere-pro-discussions/m2ts-files-no-longer-playing-in-premiere-projects-nor-usable-in-encoder/m-p/14606615
    And its seems a while ago they stopped supporting M2TS formats, this forum I sent you was posted this year in 2024 so maybe it can give you more insight on this. Hope it helps!
  • Marius Dudu
    August 15, 2024 at 8:21 am
    So what is the proper format to export lossles from Premiere and then to import into Vegas ? – in my case video is 1920×1080 interlaced.
  • Hector Vera
    August 16, 2024 at 9:44 pm
    Not sure what lossles means so if you can explain that, it would be good. I believe I have also rendered videos of 1920x1080p before as well in Premiere Pro. I just upload that video on YouTube afterwards but I am sure if you render it to MP4 or MOV, you can send that render over to Sony Vegas afterwards if anything.
