Activity Forums Apple Final Cut Pro Legacy export alpha channel
  • export alpha channel
    Posted by Amanda Obringer on June 8, 2007 at 1:00 pm
    I need to export a video clip with an alpha channel fur use in Flash. I have used the chroma key to remove the green screen, but am not sure what I need to do to preserve the transparency on export.
    any help would be GREATLY appreciated!!
    Amanda Obringer replied 17 years, 7 months ago 3 Members · 3 Replies
  • Russell Lasson
    June 8, 2007 at 2:40 pm
    Export using the animation codec with “Millions of Colors+” turned on.
    Export QuickTime movie – select Custom Settings. Change the compressor to Animation. Select Advanced underneath it and change Millions of Colors to Millions of Colors+.
    -Russ
  • Fernando Alessandri
    February 6, 2009 at 5:10 pm
    Hi, did you ever figure out how to export once you’ve made the greenscreen transparent? Thanks.
  • Amanda Obringer
    February 6, 2009 at 6:46 pm
    i did. it is a russell suggested: export as animation with millions + colors.
